Pole building size for lift
Thread Starter #21
2021 Jeep GC 5.7 TrailHawk
If I get a floor plate one I think 12 will do I’m 6’ tall I want to walk under the car
A lift would be nice! You’d be surprised at how much more room another 2’ in either direction gives you. I think I know what you mean by a floor plate one where you drive up on it. It works good for storing a car over and under but those are not ideal for working on your car as far as changing tires, working on brakes or many other things under the car. My opinion is a 2 post lift is better for actually working on your car. Also, 12’ headroom is very tight if you want to walk under your car. A neighbor put in a 2 post lift and the posts would not clear the 12’ ceiling when he tried tilting them up to install. The base plates for the posts increased the rotating radius by a little more than an inch and the posts hit the ceiling when they were tilted up. He had to get the posts modified to install them. You should check the specs for any lift you are thinking about before you design your concrete floor to see if there is a minimum thickness for installing the anchor bolts for the posts. Good luck with your project!
That’s disheartening haha was hoping 30x30 would do it..
You will be surprised how small 30x30 is...
Just got home. Here's what it looks like with cars. It's packed. I recommend more width, at the minimum.
And when the local gators come in @ night when it get chilly...it's even more packed...
OK @Jimmy N.
So far only a King Cobra.
Thread Starter #26
Where you been at @Jimmy N. ? It’s been quiet here
I've been busy working in my too small garage, even though many consider it large.
Thread Starter #28
Same, it’s annoying
Thread Starter #30
Thread Starter #31
As long as not an actual cobra, the deadly kind 😉
Furds can be quite deadly, it seems. Especially after a show.
You always leave early for protection. That's what I did today.
My father used to tell me that as a kid...;)
With a python as garnish.
I think our boy Davie...would rather live in the jungle...:unsure::unsure::giggle:
Demonic Cat
It all tastes like chicken I insist it really does, try it like the blindfolded Pepsi challenge
I used to use that trick when I was seventeen
