- Member ID
- #1139
- Messages
- 3,432
- Reactions
- 8,147
- Likes
- 252
- City
- Nanticoke
- State
- PA
- Country
- United States
- Vehicle
- 2016 Challenger He’ll Cat
Most Home cleaning units can not test injectors as accurately as ID can. I have a home unit, pretty good one at that, good for everyday normal car stuff but I send my ID injectors to ID for check out. But you have to specify if you do send them to ID that you want before cleaning test data and then after cleaning test data to know if they had an issue prior to cleaning or not or they will just clean and test them and see how they match after cleaning. Allot test fine at 2ms to WOT but get fouled around idle and part throttle reaking havoc if one or more are rich the other cylinders run lean from O2 sensor corrections for the rich ones. Seen it many times especially with pump flex fuel use.
