2023 Final Edition
Latest release.
Yeah 7.1 lbs?
HWDan
Home of the Hellcat
2017 Charger SRT 392
All I got was the hulk leprechaun is heavier :unsure:
7lbs boost more then a redeye maybe:unsure:
CF wheels weigh 7.1 lbs 🤫
Its showing heavier
Im thinking boost or some scientific weight of the fuel.
They really are rolling with this mutant leprechaun thing. Yeesh
Illegal_Demon
Open Space
Ok they are both standing on the scale but it ONLY reacts once the right side is "activated". To me this is screaming different fuels used and diff density of said fuels allowing u to run more power for a given volume (per gallon)...
so this chart below shows density of gas is 6lb/gal...while pure ethanol (glowing yellow, yellow iv bag...CORN is yellow) ...is 6.6lb/gal...e85 is 6.5lb/gal...t
https://www.engineeringtoolbox.com/alternative-fuels-d_1221.html
The 7.1lb seems to be suggesting total added density for a volume of fluid...but a full tank ..20g would be +12lbs....not 7.1...+10lbs if e85....maybe they are thinking u run 1/2 a tank at the track??
I think I'm on the right track but not quite sure how they exactly get 7.1lbs...
to get the 7.1lbs right (assuming a full tank) we need a fuel with a density of 6.3-6.4/gal which is roughly E65 ..which i know doesn't exist...)
Find that density tho and that's what it likely runs on....
HWDan
Home of the Hellcat
What about E90? I've seen E90 speculated elsewhere for this car.
Less weight is more power
Let's see, where have I seen that before???
:unsure:
What
Is this leper-con motif? I am literally astonished. How does that connect to anything that has.gone before? Id still like to see a hybrid AWD ass kicker myself....
Not readily available.
Its magically delicious
The yellow-eyed dude in the helmet appears to be wearing a fire suit with respirators. So, I think it will run on nitro methane.
Either that or it's actually going to be an EV. Safety first. :LOL:
Demoniccat
7.1 More boost and 7.1 lbs wheel weight would be nice.
screw it I’m greedy 7.1 liter also. That kind off Rotating mass (ooooops there it is again smart ass) wouldn’t need to spin fast just raw unadulterated torque to git er done with lots of wide tire but no poke out.
Demoniccat
can’t imagine the cooling could be good on those mod style challenger Bird/Daytona style conversions with the nose cone covering a vast amount of radiator area not to mention the two air/water inter coolers each side down low.
What if it's sold "as is" and no warranty?
Demoniccat
Make worth buying without out warranty.
Make it worth buying with out spending large worth.
Don’t see either coming to fruition just being realistic not negative.
433 C.I. = 7.1 liters
I know. No way.
