Hood scoop modification
HMBRGLR
Stockton
2022 Challenger Hellcat
has anybody looked into modifying the inside of the hoodscoop to better direct airflow to the filter. i will post pictures in a minute of what im talking about
HMBRGLR
HMBRGLR
Stockton
Thread Starter #2
So this area just allows air coming in the scoop to just go into a void behind the plastic that mates to the airfilter box. I would "think" if this was blocked off it would allow a rate of airflow into the filter area. Idk im no airflow expert. Just my thoughts.
Sent from my SM-N981U using Tapatalk
HMBRGLR
HMBRGLR
Stockton
Idk something like this
22RENBS2 & 170
My wild guess is: As long as enough cold air is entering the airbox to feed the SC and it is not sucking hot air from the engine compartment, it does not matter one bit. I do not know the air flow values so I cannot be sure, but since SRT engineers did such a good job on everything else, I would expect it is fine as is.
Back in the day with NA engines, increasing air flow to increase pressure at the carb might make a difference.
HMBRGLR
HMBRGLR
Stockton
i deff. agree that it probably doesnt make a bit difference. just curious if anybody else had wondered this or looked into it.
has anybody looked into modifying the inside of the hoodscoop to better direct airflow. i will post pictures in a minute of what im talking about
Airflow to what? Lol
HMBRGLR
HMBRGLR
Stockton
2022 Challenger Super Stock
There is a ton of time and money spent to optimize the airflow in all new cars. I’m sure there can be minute improvements but I believe even CAI on newer cars only offer slightly modest improvements.
HMBRGLR
HMBRGLR
Stockton
agreed
