8HPXTREME WITH A LITTLE EXTRA !!!!
Trader history for hellno (1)
I HAVE AN 8HP90 HERE THAT HAS MORE THAN THE NORM
A CLUTCH DRUM 7 GPZ WITH UPDATED PRESSURE PLATE NOT THE THIN ALTO THAT STILL HAS A FLEX PROBLEM (6 CLUTCHES IS OEM SET)
B CLUTCH 5 CLUTCH SET WITH PERFORMANCE STEELS UPGRADED FRICTIONS AS WELL (THERE IS NO ADDED FRICTIONS HERE BECAUSE ITS NOT A PROBLEM AREA)
E CLUTCH DRUM 9 CLUTCH SET OEM CLUTCHES (FACTORY IS 7 AND THE USUAL UPGRADED ONES HAVE 8 )
C CLUTCH DRUM 9 CLUTCH SET OEM CLUTCHES (SAME AS ABOVE)
BILLET E DRUM DLC COATED AS WELL(DLC COATING IS NOT OUR NORM BUT ONLY HELPS )
D CLUTCH DRUM 6 CLUTCH SET OEM CLUTCHES WITH UPDATE PRESSURE PLATE (FACTORY D PLATE FLEXES THE SAME AS A PLATE DOES ) HAS PERFORMANCE STEELS
NEW PUMP
UPDATED VALVEBODY
IT WILL BE VERY IMPOPRTANT TO DO ALL THE PROPER INSTALLATION STEPS INCLUDING THE QUICKLEARN !!!!!!)
I HAVE TESTED A SIMULAR SET UP IN MY CAR HERE IN MEMPHIS AND EVEN AJ BERGE WAS IMPRESSED THAT WE RAN FULL 19 :p:pDEGREES TIMING THROUGH THE SHIFTS (YOUR TUNING HAS TO BE PROPER ) YOU DONT HAVE TO TURN OFF TORQUE MANAGEMENT TO ACCOMPLISH THIS !!!
YOU MUST HAVE A CORE FOR TRADE AND YOU WILL BE FOR REPONSIBLE FOR SHIPPING
5695.00 :eek::eek::eek::eek::eek::oops::oops::oops::oops::oops::oops::oops:o_Oo_Oo_Oo_Oo_Oo_O YES ITS A ONE OFF UNIT AND ITS AN INCREDIBLE DEAL
Wow that is a great deal
Will this make my M6 faster?
:unsure:
T
:unsure:
yes, we can convert your car to an A8 so you can use it
Geeeez smokn deal! Just paid for a PURR stage 3 trans, converter and transfer case for my Trackhawk smh. This is a great freaking deal!
:unsure:
unfortunately theres no hope for ya :LOL:
NEW PUMP
UPDATED VALVEBODY
Do you take affirm? 😂
He doesnt but I do so if you want a trans we can work it out
